Hi all,
I have a 3 zone wet underfloor heating system and I started to use it over the past few days after the summer. I've noticed that when the heating is on I can hear what I assume is water running through the pipes in the area where it's on (it's not near the boiler or the manifold) so the noise must be coming from the ufh pipes. This only happens for one of the three zones.
The noise is like a gushing noise (not hammering, tapping or clicking) and the best/only way I can describe it is like the sound of water running through pipes when a toilet cistern is filling (or similar to the noise of an areoplane flying in the distance). The system has been installed for 6 years and this is the first time I've noticed it. Over the summer all I've had done is had the boiler serviced and the burner seal replaced on the boiler. The system isn't losing any pressure and all zones are heating up as expected so I'm a bit at a loss as to what might be causing it.
Any sugguestions would be very welcome!!
