I wonder if you can help me, I have a house, that has a wet under floor heating system with ground source heat pump. We have UFH on the ground floor, and bedrooms above, but we have just extended into the loft. I want to install wet under floor in our new bathroom in the loft. Being as it is a new build the house is super insulated, so we have never had to run the heat pump at full blast. In fact it has only ever been set on its minimum setting even in the worst of the weather so I am sure the heat pump is more than capable of running one more room. My question is this, is it just a matter of my obtaining another manifold and running new 28mm flow and returns of the existing 28mm flow and returns to the new manifold, and obviously running loops to and from the new manifold. With the GSHP I realise the pipe centres are only at 100 mm apart as the water temperature is lower than a normal gas/oil boiler, thus you have to run more pipework. And there are no zones on the heating system, all the controls are from either the manifolds and one room stat in the hall and an outside temp thermostat on the side of the property. Thanks.
