Hello,
I need some advice on my DIY wet under floor system I installed in my new build house recently.
Basically I have fitted some JS Speedfit 15mm pipe into a 100mm insulation foam board by routeing the pipe slot into the foam and then pressing the pipe into the foam slot at 200 mm centres.
I then placed flooring chip board on top of the foam/pipe set up.
It’s all quite tidy and I was quite chuffed with my efforts
However I have been talking with a heating engineer that tells me I should have used spreader plates in my under floor construction (these are aluminium plates that hold the water pipe at 200mm centres) are he says help significantly distribute the heat from the water pipe better into the rooms.
Is this true?.
I assumed the spreader plates was just a way of holding the water pipe in place at the 200 centres and no efficiency gain.
Is it true what the heating engineer is saying or is he just trying to drum up more work ?.
But if he is right can anyone tell me how much efficiency I’m loosing?
If say 5 (five) % then it's not really worth my while pulling the floors up...if however its 100% then I best consider using the spreader plates.
I would be very grateful for any relevant freed back.
Dave
Is this true?.
Dave
