wf540 error
11 Jan 2009
London
hi guys
i have the wf540 1400 spin and about 4 mths ago i changed the bearings on it all has been going fine untill today when the power light flashes fast and buttons 1 and 2 are on the machine auto started itself.
can someone please help with this error
that means error f12 ,try and make sure wires are connected to pcb ,if that dont work you need a new pcb emw in notts do ex boards for about 30 quid that your best bet
hi rocks1
do you mean the board at the fromt of the machine where the little molex type connection with 5 red wires goes ?
no the board is at the back on the bottom on the left ,remove the rear bottom white cover all is revealed
heya Found a broke wire :oops:
soldered it fixed the issue :)
thanks for pointing me in the right direction much appreciated
