What’s good practice with spare wires at panel
20 Oct 2010
Lanarkshire
Hi if I have 8 cores per zone what would you recommend doing with the spare ones,twist back on the outer sheath or cut flush with the outer sheath ?
When I was doing wiring I'd coil the spares either around the wanted wires or coil around a screwdriver shaft and leave 'hanging' inside the terminal block. If the wanted wires are tied into a form then I'd also include the spares into the form.
Twist them together keep them tidy, do NOT cut them flush you may need spare cores for a number of reasons in the future
ISTR that wiring standards say that unused cores within a cable should really be grounded.
That way they cannot be susceptible to stray interference and re radiate it.
Although what the alarm guys do is probably something completely different. :)
I completely agree with keeping them with long tails for future use though.
