I bought a pair of 10" adjustable spanners at Wickes a month or two back. Was planning to do some plumbing this afternoon with 22mm pipes. Went to do up the first nut... Spanner not big enough. Thought to myself "that's strange, it was big enough for all the other 22mm compression nuts I have used".
Tried my 22mm compression nut spanner, still not big enough. Then I realised what it was: Wickes compression fittings use a slightly larger than standard nut. Thus forcing me to go down there and buy a larger spanner, which I don't really need, as every other brand of nut I have found is the right size. I could register my displeasure by just buying new joints from a different supplier I suppose, but I can't be bothered.
Who bets when I get down there that there is a special Wickes-compression nut spanner?
