Not tiled a floor before. I've read the FAQ, which recommends a BAL flexible adhesive.
I'm unsure which one. Can someone advise?
Tiling WC to match bathroom. Area is 950x 1820mm, using 300x600mm porcelain tiles.
Luckily it's only 9 tiles and minimal cuts.
Floor boards have been screwed down tight. 15mm wbp has been screwed on top at 200mm spacing. Skirting boards removed, new ones will be fitted after.
The joist span is 4.5m (there's a brick wall seperating the wc and bathroom), however, there's now a steel beam supporting the wall, so the span is supported at 1.5 m. So hoping very little deflection and movement in the floor.
Floor is uneven - a 10mm drop over the 950mm width. Aiming to level it with the adhesive.
Choices:
There's an own brand flexible single part adhesive, from a known tile shop, for £20. Apparenly its good for ply, ufh and porcelain.
There's BAL flexible single part for £30, which is "suitable for installations suitable to minimal vibration, shrinkage, deflection of heated screeds"
There's a BAL flexible adhesive, elastomeric for £54 suitable for areas with "movement and vibration"
And more BAL flexfibre polymer options for £20 to £30, all suitable for vibration and movement etc.
I have no idea what to use. I don't want to waste money if the cheap own brand one will do it, although, for the sake of an extra £30 - I dont want to have to re do the floor in a year if it does balls up.
Thanks in advance for advise!
Choices:
