What Am i Doing Wrong here before i blow up my House!!
24 Sep 2010
Oxfordshire
Trying to hook up my Honeywell CM927 to my Vaillant Ecomax boiler.
I hardly know how to wire a plug so bare with me!
So from the receiver, left to right ive got
N (Blue) going to N on the boiler
L (Brown) going to L on the boiler
L (Yellow & green) to earth on the boiler
A (Black) going to 3
B (Grey) going to 4
N, L and earth on the boiler is the mains already. Is it ok to shove another set of wires in the same holes as i have to here?
At present my power trips as soon as i plug in the boiler!
The reciever does not need an earth, get rid of the wire between L and earth and your stat will work ok.
L (Yellow & green) to earth on the boiler.
If you had read my Original Instructions carefully, you would see that it says that the earth wire is NOT used.
Nowhere did I say that you should connect the second L terminal to the boiler earth! :rolleyes:
Yes. Otherwise I wouldn't have told you to do this. :rolleyes:
PS Let's hope you haven't damaged the receiver.
Read your thread from start to finish
Its a bit ignorant thanking the bloke when others have given u the required information before hand, with not even a thank you!!
