I am thinking about a heating/dhw system for a HMO that will have many showers so need good hot water flow rates. As the tenants may wish to have different room temperatures, at times the heat load could be very low.
As I understand it, the ACV Heatmaster condenses very well while producing DHW and gives a good flow rate. Additionally being a high water content boiler, it is more forgiving to a low heat demand without having to have a radiator that is always on to act as heat dump loop or lots of cycling of a burner.
So apart from the size of the ACV Heatmaster, way is it not used more?
Are there more restrictions of where it can be sited then a normal boiler plus hot water tank?
