- Joined
- 5 Nov 2010
- Messages
- 389
- Reaction score
- 3
- Country
I want to create a single paving block mowing strip between the lawn and the fence/gravel board. I absolutely hate strimming - probably because I'm useless at it!
I had the paving blocks installed for a patio last year and will use the same.
Obviously these will not be walked on so I'm sure the preparation involved doesn't need to be as thorough.
The question is, what type of base do I need? Do I still have to use mortar/cement? Could I get away with simply just digging the soil then plonking them in tightly or just use sand?
I have done some research already but I'm easily confused as my experience in this is limited especially with the types of sand, mortar & cement etc. I've learned building sand is a no-no as it become fluid when water-logged.
The blocks will measure 60mm in depth, 210mm length & 140mm wide.
Thanks very much.
Thanks very much.
