what base should i use for a gym in a shed?
20 Jan 2003
I am moving to a house without a garage,
I use my current garage as a gym.
I want to errect a shed in the back garden of the new house, should i go with slabs or a concreate base?
and would the shed need to go on beams?
or should i go for a metal shed?
why not do the same as your current shed? since it works
metal shed = summer oven
Use a solid concrete base, it will support the weight and movement of the machines much better. May be worth overlaying the floor with ply to increase the strength as well.
In my opinion concrete is too permanant and cold for a shed. I'd build a wooden floor if it were me. Warmer and friendlier. Better still is to build the gym as a summer house. If ever you sell - it adds value.
i was refering to the base not the floor. most sheds come with a floor and 2 x 2 battens underneath. The flooring is either osb on the cheaper sheds or t&g for the better ones. A concrete floor will give you a very stable base. overboarding the floor with ply willl help to strengthen it, especially if you are using it as a gym
cheers guys.
i dont have any machines it is all free weights,
so i want to make sure i dont crack or break anything with them.
I thought the shed would need to be raised from the based it is on?
it will. a concrete base then some treated 2 x 2 bearers will do the trick
where would i get treated 2 x 2 bearers?
i am looking for a shed size of 13 x 10ft
If its going to be 13x10, would it not be cheeper to use concrete blocks to build the shed? Also stronger, and if the total size of the building is less than half the size of the garden, and more than 5m from the house, and less than 4m high you dont need planning persision. (AFAIK)
Just a thought, thats what i'll be doing in the summer...
4m high maximum for a pitch roof and 3m high maximum for a flat roof ;)
