M
marsaday
I have to secure some metal plates to my steel channel in my attic conversion.
They attach to the truss frame in the centre of the roof (holding it up) and also attach to my new steel.
I will drill through the wood parts and bolt a plate either side. However, i also need to bolt the bottom of the plate onto the steel. I have a 12mm hole drilled in these plates and so i need to drill through my steel at this point. Inside the steel is sat a 75mm deep joist.
What would i use to secure the plate to the steel and into the wooden joist ?
If there is nothing out there i will just have them welded in place.
View media item 29224
View media item 29225
