What cable to use?
9 Nov 2016
I'm just about the change the lights in my bathroom from 1 pendant to 4 x 9w LED Downlights. I'm clear how to do everything. My question is due to the size of the terminals in the LED Lights can I use 1mm cable rather than the standard 1.5mm?
Thanks in advance.
Graeme
Graeme
Is 1.5 the standard?
What size is the fuse or circuit breaker for the lights?
You may not realise it, but securespark's questions were essentially rhetorical.
Although, for some reason, 1.5mm² cable is commonly used in the UK for lighting circuits, there is virtually never (if ever) a need for it in domestic installations, and 1.0mm² is more than adequate.
Buried in a solid wall, or clipped to a wall, 1mm² cable can safely carry 16A and even in the worst possible situation (cable totally surrounded by thermal insulation) it can still safely carry 8A - so it is always OK for a 'standard'; 6A lighting circuit. It is also, as you imply, easier to get into the tiny terminals of some light fittings etc. than is 1.5mm².
Kind Regards, John
