If a fridge freezer gives an indication reading of 0.00 Mohm what is the most likely cause?
Hi, It was tested at both voltages, it is operational and doesn't cause trips.
We don't know for sure, but a standard PATester will short L and N and probe on earth (through the plug).You still haven't answered the question - across which terminals, was 0.00Mohm measured?
Do you have any other tests available to confirm? A few testers also have an earth leakage test available?Hi, It was tested at both voltages, it is operational and doesn't cause trips.
Yes, standard for Seaward testers.I think that's right its a prime test 350
Yes, I wasn't suggesting sny specific causes yet - I was just suggesting a confirmation test for a very low IR result.I would think more likely is the seals on the mineral insulated defrost heater have broken.
