I hope someone out their will be able to help regarding my dilema,
I am wanting to replace the light fitting in the bathroom with a proper zone 2 flush light fitting which i have purchased but when i undid the old light fitting inside was a choc block with 3 loop in lives into one of the connectors, 2 neutrals into one of the connectors, 3 earths into the third connector and finally the black switch live wire with the red tape on into the last connector as should be but my dilemma is the new light fitting has a choc box pre-fitted into the cover with only connectors for L,N,E. I will have no problem wiring up live to switch live, neutral into neutral and earth into earth but where can i put the 3 loop in lives. There is not the room to remove the prefitted choc box and just putting the existing choc block in its place so would it be ok to wire up as should be and just leave the loop in lives in the connector they are in and just place them seperately into the cover which on their own would fit, and if so should i cover with insulating tape or not ?
