What carpet underlay for new concrete conservatory floor?
16 Nov 2004
Hi, the floor in our new conservatory is now dry. We need to retain access to a sealed manhole and have chose to have carpet so it can be taken up easily if there are drainage problems and it will also be a bit warmer underfoot.
I've used Cloud9 foam underlay before and really like the stuff. They do a 10mm Contract underlay with a silver 'reflective' layer. Is this the kind of underlay we should use? If not then which do you recommend?
Also, can I lay this straight on to the floor or will it need to rest on some other type of protective layer.
if you've not got kids then carpet will be ok.
i like carpet but i've gradually moved it all upstairs and replaced with tiles and laminate.
appreciate the thought process on the need for access but i would still put laminate down.
as for carpet underlay then i don't see anything special being needed assuming the base has a dpm. i generally like felt underlay as opposed to the sort of curvy rubber type.
i think for an all belt and braces approach then putting a lightweight vapour barrier down 1st would be ok and not too pricey.
