Hello everyone,
I would be grateful if anyone would answer the question: what actually causes the condensation inside double glazing where there are no seals present?
I have read that it's the seals that go that produces the moisture. However, with my windows there are no seals, the panes of DG are just inserted into and held by the wooden frames.
I would like my DG to last a while longer so I was wondering if the condensation in my windows has come about by excessive heat on very hot days, that is, the strong heat has damaged the window in some way where condensation is then the persistent result. If this is the case then I could put a covering on a couple of my downstairs windows to stop the heat on hotter days from causing the damage to the windows that are still presently condensation-free.
Thank you in advance for all who answer.
