What cement mix to use?
31 Aug 2010
Essex
Hi
I am looking to bed in sleepers, with cement, for the edge of a paved path and to edge some steps, the sleepers will be walked on.
I think I need them to be secure like a brick wall would be at the bottom, so that I can fill the space between them with Type 1, compact and then lay my paving.
What mix of cement should I use i.e. what ratio cement to sand, presumably no gravel is used? should it be a moist or wet mix etc?
All advice would be greatly appreciated.
Hi
Cement and sand = mortar
Mortar + gravel = Concrete
They can be bedded and haunched the same as any other edging, i.e. with concrete.
I personally steer away from wooden products that are in contact with the ground as I prefer my jobs to last. Modern 'sleepers' are pants and despite the fact that they are treated does not mean that they will not rot.
A lot depends upon how exposed the timber is and its location within the garden. You will often find that timber products last a heck of a lot longer if they are on the sunny warm side of a garden as opposed to those that are shaded and constantly damp.
The problem is timber stuff is easy to work with, easy to transport, and easy to fit. A real boon for diy'ers.
OK so a 80mm x 4:1 damp mortar mix would do the trick?
Yep pretty sunny and will get little foot fall.
