Hi all
I've got a builder in to do my bathroom. This used to be two separate rooms (lavatory and bathroom). Each used to have a ceiling light. I've knocked the two rooms in to one. The electrical work involved has been:
1) Putting in a new mirror (with lights and a shaver socket). The electrician has simply used the cable that used to feed the lavatory light to feed the new mirror.
2) Replacing the old ceiling light in the bathroom (fluorescent tube) with 6 downlights. The switch that used to operate the light in the lavatory will be used to switch these lights. The ceiling is quite high - about 2.6m.
Firstly, is this work notifiable? The builder says no, as all he is doing is moving around existing circuits and daisy-chaining the spotlights from an existing light fitting.
I submitted a notification to building control in respect of the wider renovation works and mentioned the changes to the bathroom in that notification. In the notification I stated that all notifiable electrical work would be undertaken by a qualified electrician who would certify the work through an appropriate competent persons scheme (the builder's quote stated that all notifiable work would be undertaken by a "Part P qualified electrician"). Therefore if the work is notifiable, I need the builder to get his electrician in to do the work and submit the relevant paperwork, don't I?
If it is not notifiable, do I need any documentation? We will be selling the house in the next year or so, so I need everything to be properly documented.
Thanks!
EDIT: I know that some people hate using downlights to light bathrooms and kitchens. The truth is, I don't much care what lights are used but my wife does, so downlights it is. Are they designed to light bathrooms? Probably not. Are they as good as proper lights designed to light bathrooms? No. Is it worth arguing this point with her? Absolutely not. If it helps, we were going to have downlights in the kitchen but I did manage to convince her that they would be unsuitable in that room so we now have proper ceiling lighting and a modest amount of LED lighting under the worktops, but she could not live with anything other than downlights in the bathroom.
Thanks!
