Have done various jobs on my central heating which have required drain and refills, have always flushed the system a couple of times and then topped with inhibitor when done.
i've also used a cleanser a couple of years ago but i'm certain that was all flushed out. i flushed it, a few months later had to drain and fill due to a leaking pipe and last december had to drain and fill to add some rads.
I'm swapping another couple of rads and valves and fixing a leaky magnaclean so will need to do another drain and refill.
Even after flushing and filling it still comes out brownish, should I keep doing it until it runs really clear.
hopefully will not have to touch it again after this so just want to take the opportunity to get it dones as best as possible.
i'll be refilling with x100 and have a couple of test kits to amke sure it's dosed correctly.
Cheers,
Cheers,
