What Combi Boiler ?
5 Jan 2009
Hi All
I have always have had a cheapy Ferroli for about 14 years and it's only played up once/twice as its a VERY simple set -up and simple to work.
I am looking at replacing back boiler/tank etc with a new condensing combi.
What do you guys recommend, it's for a small 3 bed, so 24Kw would be enough.
Cheers
__________________
This is the most commonly-asked question on here, do a search for the full range of answers
I recommend Intergas, if you want a 24kW you then you need the Combi Compact HRE 24/18
Cheers i will have a look, plenty of people on a non diy forum recommending VAILLANT ECOTEC PRO 24 COMBI BOILER
I just looked at the sysytem it's ike a supercomputer !!!
Can not even see how to fill/top up CH sysytem !!!!
There is no filling loop ??
My Ferroli 701 is basic and so simple...
The Ecotec Pro is the bottom of the range Vaillant and IMHO isn't worth the money you have to spend to buy one. You're quite correct, there's no filing loop on it, you have an external one. That's not necessarily a bad thing though - external loops are more reliable and cheap to replace if they ever do spring a leak
Why is it not worth the money, what is the benefit of a more expensive type ?
Cheers
Cheers
I actually suggested a cheaper boiler rather than a more expensive one, but one that is also better. You should find that the Intergas is about £120 cheaper than the Ecotec Pro, but even if they were the same price I'd still rather have the Intergas in my own house.
Take a look at the W.H 80 or 90 model from ravenheat
nice looking boiler 7 year warranty , whisper quiet , very well thought out for servicing & maintenance with access ect
No plastic/composite all brass/ metal manifolds
Heat exchanger manued by Audi
I've never understood why some people in our trade get their c*** out at the suggestion of involvement from the motor industry. Look what happened to the idea of rubber hoses.
good point may be ??
Intergas heat exchanger afaik was cast or is cast by mercedes?? or some german car manu ?
Fernox boiler buddy flitration was designed or based on F1 oil filtration ?
WB make a made a point of there stir /friction welded heat exc on the new compact , 1 boiler manu has been using this tech on there heat exc's since 1997
Intergas HEX is cast at their own factory.
Now what would be cool is if they did a dual stage burner like Rinnai ;).
there was some car manu in-put at the beginning in the design stage or ??
bloke told me at Atmos seen a video if I remember correctly ?
(might have been skoda ? lada ?moskavitch ? only joking :) )
