- Joined
- 27 Jan 2008
- Messages
- 24,903
- Reaction score
- 2,877
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
We are looking for a new house, and we noted the home energy efficiency of one house we liked was G the lowest rating, it said it could be improved to an E, but we were unwilling to commit ourselves with such a low reading.
The estate agents said it has now been improved, and they have never seen a house rejected over the home energy efficiency rating and it was down to lights fitted, however we had considered the house and had realised there were a number of factors.
1) No hall, front door opened directly into first room, and stairs went direct from room upstairs so heat would migrate upstairs and likely a draft when opening door.
2) In many places there was a sloping ceiling, so clearly limited insulation between room and roof.
3) There was no door between conservatory and main room, so in winter heat loss possible and in summer heat gain.
4) Wet under floor heating fitted, no idea if insulation fitted before it was laid.
As far as I am aware bulbs are not part of the home energy efficiency rating as clearly they could be moved house to house just to bump up rating.
I would assume the person doing the home energy efficiency rating would inspect any completion certificates to ascertain if the LABC had over seen the building work when underfloor heating was installed and when conservatory was added, I am told LABC will insist on more safe guards when no doors between conservatory and house.
Clearly when viewing a home all certificates are not provided, you rely on the energy efficiency certificate to show some one has done all that on your behalf. However having just sold father-in-laws house, when the came to inspect, they aimed a meter at windows, looked at boiler type, noted it had solar panels, etc, but since father-in-law had died, too late to ask questions like if cavity wall insulation installed, and when we had cavity wall insulation fitted, we found extension already had it, and when tile replaced in extension found insulation packed between ceiling and roof tiles, however we did not see the inspector with father-in-laws house check any of that.
So is the energy efficiency certificate worth the paper it is written on?
I moved house we are using, the old 1954 built house uses around half the fuel to the 1980 built house, I would guess many reasons, older house has a hall, and modulating gas boiler the newer house has older boiler and is open plan with stairs from main room and no hall and a semi so could be gaining or losing heat to next door.
So the house we looked at with G rating has been rejected, but we are likely to see low ratings again, so what do you need to do when buying a house, how important is that certificate?
