What depth will a terraced wall be between the neighbours?
8 Apr 2009
Hampshire
I need to put some long screws into a wall which is partitioning us and our neighbours (terraced 80's build) to hang kitchen cupboards. I want to use these http://markgrantcables.co.uk/shop/i...ducts_id=126&zenid=569u7ien94p330jiel44rnkfs1 but fear drilling into their house. Am i worrying about nothing? The hole required is 100mm and our wall is platerboard, cavity and breeze block any help would be great, thanks
thanks although not sure how i'm going to do that as the houses are built staggered so i've not got their wall and ours directlly next to eachother if that makes sence!
Don't fix thru plasterboard , cut a 100mm strip out along the top edge where cup'ds fix and screw same depth ply or mdf to blockwork, then you have a firm background you can fix cup'ds too with standard length screws.
