Bit of advice please.
I want to replace some existing plastic waste piping with 40mm plastic waste.
I need to connect this to an existing plastic waste of an unknown diameter.
To try and find out the diameter I wrapped a strip of paper around the pipe, measured the circumference and divided by pi (to get the outside diameter).
This gave me a number of 57.32mm for the outside diameter (obviousley my paper strip measurement wasn't EXACTLY right), so my question is can anyone tell me what size the pipe is - I believe I need to know the INSIDE diameter for plastic waste.
Could it be some wierd size or is this close to a standard size?
I want to by a reducing connector to go from the larger pipe down to 40mm and do the rest of the connections in 40mm.
Attaching a pic if it helps!
Rgds
[/img]
Rgds
[/img]
