I decided to hang a large picture above a radiator in my living room (the wall being a partition between living room and kitchen). The walls are plasterboard. I (stupidly) assumed that there would not be a pipe in the wall directly above the radiator (from the middle). I drilled into the wall, into what I assumed was a stud, planning on inserting a screw. However, the drill encountered a great deal of resistance after perhaps an inch, so I (stubbornly) gave it a bit of welly, but no go. I then came to my senses and stopped. Shining a small torch in the hole showed only a white region, no evidence of wood or metal. However, I've since bought a pipe detector which gives a signal at that point.
My question is, was I a whisker away from drilling into a pipe? If so, is it encased in plaster or something like that? There is another radiator in the bathroom directly overhead, and one of the pipes from this is about an inch to the left of the hole. Could it be this pipe coming down to join up with the other radiator?
I guess I'm a little paranoid now that (after filling the hole), I may at some point get a leak because I damaged a pipe or something, so any advice to set my mind at rest (or any action that should be taken) would be greatly appreciated.
Colin
Colin
