Hi
Around 4 months ago my son removed a 3 way normal light switch from the sitting room because he was plastering.
I need to replace the switch with a dimmer switch, but I have a problem.
My son cannot remember how the wiring went, and I can't figure how it even worked in the first place.
This is what used to work on the 3 way switch;
Switch 1- made one ceiling light work
Switch 2 - made the second ceiling light work
Switch 3 - made 4 wall lights all work at the same time
This is the wiring I've got;
2 cables coming in - both twin & earth.
I want to get a 3 way ???? 400 watt per gang dimmer switch.
The new lighting I'm getting is;
4 wall lights (total 8 bulbs max 60 watt per bulb) but I'll have to fit 40 watt (8 x 40 = 320W) which is OK for the 400 watt gang.
2 ceiling lights - 3 x 60 watt each - total per gang 180 watt.
MY QUESTIONS;
Do I need a One Way or a Two Way Dimmer Switch?
How would I wire this up?
The black wires have no 'red' tape attached.
Twin & Earth: Black/Red/Earth
Any help would be appreciated as I cannot fathom how to split the power for 3 individual feeds.
Thanks in advance.
Stephen
MY QUESTIONS;
Thanks in advance.
Stephen
