Daughter has bought flat. In kitchen she has had installed washing machine which is cold feed only. Beneath the sink the little feed with the blue 'tap' on it is open to allow the water into the machine. The one with the red 'tap' on is closed as it's not needed....however the threaded base is not capped/blocked off and I fear that in stowing and removing things from the cupboard where these are sited, she may unwittingly bash this valve partially open and have water leaking ( would that happen?).
Is it a 'blank nut' she needs to buy to screw onto the thread and close it off, or is it something else? Where do I go about buying said item and what doI ask for? Are they of a standard size or do I have to get her to measure the valve?
Any help would be appreciated
