Hi folks,
Building a polycarbonate covered lean to that will get some harsh weather over the years- getting lashed right now...
I have a roll of lead 240mm deep (6 m long).
The pitch is 12x5.5 inch which I thought was pretty steep so thought I would not need so much on the overlap...then I read that upstand must be 75mm?
Re the overlap I get that more is better as wind will have to drive rain uphill further before it goes over the polycarbonate, but after it has done so, why would it matter that the drop goes on upwards 75mm or more before turning into the chase.
Can I squirt a band of sealant under the overlap and stick the flashing onto the polycarbonate? Or CT1?
The chase will be cut blind into render- no idea where the brick courses will be? Does this make any difference with the option of mortar or mastic? Never done this before but think I read that mortar will more often fail due to lead expansion-contraction.... But would the mortar not need something solid to support it?
