Hi
Looking for some advice.
We had a rad in the hall not heating up (just a little heat at the top with lots of heat at the entrance into the rad).
Pipe heated up to the TRV and the bit of panel next to the inlet but not much else.
Tried taking off rad, flushing with water - lots of little black flakes came out but did not fix the problem.
Have now installed new radiator but only heating alittle at top with both TRV and lock shield fully open (also tried closing abit as well) but nothing worked.
Opened the lock shield valve into a bottle with a good flow of water squirting out.
Hot water is getting into the radiator as the bottom bit of the rad where the water goes in is roasting.
So if water is getting into both sides of the rad, what could be the answer for a lack of heat?
Had to give up as well on the whole fix so no pressure for hot water as the lock shield connection to the microbore was leaking loads. Not a successful Sunday.
Any thoughts welcome.
Fluff
Fluff
