K
KillingTime
I'm in the process of replacing 30 year old 8x2 Ft T&G floorboards - which creak.
Some of the floorboards are rotten because of repeated bathroom leaks...
I've had to pull up most of the flooring in the house in order to get at central heating pipes and electrical wires. Given the fact that the original boards were T&G and nailed down, I've had to cut most of them up with a circular saw. Pulling the nails out proved a false economy because the board just crumbled around the pressure of the hammer claw.
In putting new board down (8x2 Ft P5) my main objectives are:
A) Stop the creaking.
B) Be able to pull individual boards up without wrecking the board (so it can go back down again) - so I can get at the pipes if they need attention.
I don't want to have to break out the saw every time I need under floor access. Quite why anyone would want to put a floor into a modern house that does not allow access for under-floor repair is beyond me. Car manufacturers don’t make engines that need to be removed just to change the spark plugs....anyway
I intend to saw the tong & groove of the boards I've bought and lay them so they start & finish on a joist (staggered). Then screw then down.
I realise house builders don't do this because of the wastage & cost.
What sort of expansion gap should I leave?
Can anyone see a problem with this arrangement?
Thanks.
Thanks.
