My handyman is decorating a small bedroom for me. It had wallpaper on the lower half of the walls, finished with a border, all of which was stripped off. The area which had been papered was rubbed down with sandpaper, washed down and filled as necessary, filler rubbed down with fine sandpaper. A mist coat was then applied (I am not sure whether he applied this to the whole wall or just the filled areas). When the first coat of full strength emulsion was applied, some bubbles appeared, which have now been sanded down. One bubble was elongated and when he rubbed it down he exposed some plastic cable ducting which was very close (only 2mm) to the surface. What can be used to fill this gap which is about 4 inches long and an inch or so wide? He has rubbed it with coarse sandpaper to give it a key but what will stick to plastic and provide a smooth finish which will blend in to the surrounding plaster?
