What fixing to attach to exposed brick wall?
20 Feb 2013
Liverpool
I have the below wine rack to attach to an exposed brick wall. It is 1m in length with the tubing being approx 10mm thick. It has 4 x 5mm fixing holes pre drilled into it.
https://www.manomano.co.uk/p/wall-m...ottles-black-metal-21370317?model_id=21360572
It came with plugs and screws for fixing, but they just seem too small for the weight that this is likely to hold [7 bottles per rack plus the weight of the rack itself [approx 5kg].
What would you recommend is the best fixing for the job?
Many thanks in advance.
Often the case, that supplied screws and plugs are cheap/inadequate.
I would use red plugs and #8 screws.
I'll second that normal red plugs will hold this no problem. There is hardly any cantilever force, even fully loaded. Get some black screws to blend in a bit better than in the pics...
https://www.ebay.co.uk/itm/384301140752
