what floor polish to use on porcelain tiles
18 May 2010
Belfast
i have polished porcelain 60cm x 60cm tiles in the kitchen. they have not long be down but with all the builders in and out they look quite dirty. i brought some heavy duty tile cleaner from Focus, cant think of the brand, but it suggests using a floor polish once you have applied this product. what floor polish would people recommend?
thanks
if its highly polished porcelain i would not use any polishes on it to start, i would get some sugar soap and hot water to wash it over, let it dry and give it a good polish with a dry cloth its hard work but might save you grief by putting any polishes over the glaze that is already on the tiles might react bad. try that first it will cost you pence and elbow grease, failing that check with your tile supplier, hope this helps
