M
marsaday
I am converting my loft and need to fit a door into my central truss. This means i need to first create a frame out of the truss and then add a door frame and then fit the door.
So i wondered what dimensions i should leave in order to fit a door frame.
I will be fitting a 1981x762x35mm door. The frame i will make will be out of 50mm wood. So by my working i need to leave a newly created frame out of the truss allowing for the door, the frame and then an extra 10mm on the side dimensions and 5mm on the top dimension . Does this sound right?
My opening ready for the new frame and door will be 2034 x 872.
Should i allow more or is this ok.
