I've sanded and squared off an old table top which is made up of about 6mm oak parquet bonded to a pine base. So it's a kind of plywood affair. To edge the table I'd like to have it appear to be one solid piece of wood so I've got a roll of thin (non pre glued) oak veneer with which to bond to the sides. Does anyone know what sort of glue I should be using to do this? I was going to just use some Bostik evo wood glue but I'm not sure if it's appropriate. Most of the advice I see covering gluing veneers online talks about large area veneering, using vacuum pressing, ironing etc, which doesn't seem appropriate for my case. I just want to veneer the table's edges, via sash clamping
If anyone has any experience of this type of use case or pointers, thickness of glue application, wait time etc, I'd really appreciate some advice.
