had a boiler changed yesterday, vented to combi, so the immersion supply is now looking for a use. the fitter left the mcb off, this morning I wanted to check that the supply was still connected to the immersion switch by checking the the red light. switched the mcb on, went to the old immersion switch and flipped it. everything went off. went to the consumer unit, the mcb and the rcd had both tripped. made sure the immersion switch was back in the off position and reset the rcd. lights flickered on briefly and went off again, the rcd probably tripped again but i can't remember, anyway no power. switched every circuit off by mcb, tried one of the light circuits still nothing, now the rcd stays in the on position.
i called a sparkie who has done some work for me in the past, he popped round, no power to the meter. call the grid, a guy comes out, goes next door where they had also rung in about no power (our feed dog legs off theirs). a couple of times it looks like it's starting up, but flickers off. eventually, it's back, guy wonders round to see me, asking if it's ok now. i ask what the problem was, he doesn't know, he didn't do anything, it just came back.
he suggested a dry joint in an underground cable may have gone and the re-welded itself?
apparently, some unexpected trips occurred while the boiler fitter was at work in the airing cupboard, but it came back straight away.
what is the likely cause and what implications are there for the future? neutral/earth issue?
strange that the suppliers fuse didn't blow.
the sparkie will be coming back to look at the immersion circuit which will stay firmly off until then!
thanks
thanks
