Fitting a kitchen at home so needed to fit isolators under the sink, in order to do that i turned the main off which was under the sink too, i ran both hot and cold taps till i assume cold water tank in the loft was empty and also the immersion heater also, my method of thinking was if the mains was off neither would be refilled!
Fitted the valves and turned the water back on, a few airlocks later and the cold is back to normal but why does the hot water (albeit cold till it warms up) run for a few seconds and then just trickle and stop?
What have i done wrong?
