I really need some help as I'm a novice at this...
I need to install a new hot water and CH system for my 4-bed house, which is currently gutted (i.e. easy to install pipes in floors etc).
As well as central heating with 10 rads, I want the capacity to run two big showers at once for 15 mins at least (for the early morning rush!) without running out of hot water. One shower is 12 litres/minute and the other 10 litres/minute. The showers need at least 3 bar to get a decent flow, according to their spec sheets.
My mains (standing?) pressure is 4 bar. I assumed I could get a big combi boiler (perhaps the Vaillant Ecotec Plus 937 with 15 litre store)
BUT... I had a guy from British Gas around to do a quote, and he said that a combi wouldn't give me enough flow for what I wanted - he said that while my standing pressure was 4 bar, the combi would only output 0.5 bar and about 7 litres a minute largely because I have an old lead mains pipe rather than a modern (22mm?) plastic one. Is this right?
He recommended a conventional boiler with a mains vented (or should this be unvented??) pressurised tank. He said that there are twin coil ones which would give me good flow and good recovery times.
Can anyone comment on his comments and conclusions?
As I mentioned earlier, my main priority is being able to run two big showers together in the mornings at a really decent pressure.
Many thanks
William
Many thanks
William
