- Joined
- 15 Jan 2025
- Messages
- 39
- Reaction score
- 0
- Country
A problem i've frequently run into, i'm drilling a hole, and it ends up too wide. This problem is always in the soft parts of the depth, like plaster. The penetration into the brick at the back is fine, because i use the correct bit size for my plug, but plaster is unreliable and can crumble, especially if damp
What do you do if you drill a hole and its ended up too big, so that a screw plug doesnt stay in properly even when expanded?
In my previous ocurrences of this problem, ive just used a larger plug and larger screw, or adjusted my plan and drilled in a slightly different spot, but this won't always be possible. Could i fill the hole with something and put the plug in while the filler is still drying so it hardens around it?
