My 1970's house has external timber walls upstairs. The walls consists of the following elements, from outside in:
1) PVC cladding
2) Felt (Looks like roof felt)
3) 4x2 timber studs
4) 50mm polystyrene (as insulation)
5) 6mm plywood
I was considering replacing the polystyrene insulation with Rockwool RW5 Insulation Slab (50mm) and replacing the plywood with Fermacell (12.5mm).
Am I right in thinking that you shouldn't fill the complete cavity with insulation because of condensation?
Is the Rockwool/Fermacell a good solution or is another product combination better? e.g. Celotex etc. I'd like the walls to be better insulated and sound proofing.
Thanks.
1) PVC cladding
3) 4x2 timber studs
5) 6mm plywood
Thanks.
