What is a grid lighting system
6 Feb 2013
Buckinghamshire
Hi
Ok I am a bit of a novice and need some basic advice I am trying to get my head around lighting and want to know what is a grid lighting system? How would you recognize a grid system and how does it differ from a normal system. I am looking at grid dimmer switches for LEDs and getting confused between normal dimmer switches a grid switches?
Thanks in advance
A grid switch is a modular means of arranging many switches.
This means you can mix regular switches, DP switches, dimmers and key switches all in the same switch plate.
I install these a lot and love them ever so much and very dearly so.
http://www.tlc-direct.co.uk/Main_Index/Wiring_Accessories_Menu_Index/Grid_System/index.html
http://www.tlc-direct.co.uk/Main_In...nu_Index/Grid_System/Grid_System_1/index.html
http://www.tlc-direct.co.uk/Main_In...nu_Index/Grid_System/Grid_System_2/index.html
Best thing since sliced bread and other things that claim to be.
grid switch is where a variety of individual switches etc can be mounted on one faceplate. E.g. if you need a 2-way switch, an intermediate switch, and two neons, on the same faceplate. Different manufacturers' ranges are not compatible.
Dunno what grid lighting is unless it's to do with suspended ceilings.
