What is strip wood flooring?
28 Apr 2021
I'm looking to get real wood flooring to lay over a chipboard sub floor. A neighbour has "strip wood" flooring which he says is thin strips of wood glued to a screed that is poured over the chipboard subfloor, much cheaper than engineered wood apparently. I can't find anything much using google. Where can I find out more about this? Is it any good?
Should'nt be screeding over chipboard flooring, you would normally level with 6mm or 9mm ply and fix to that.
