Can anyone explain the purpose of the riveted tabs on the Enlite EN-DLM981X downlight as shown in these photos?
These fittings require a 75mm hole to be drilled, which is slightly wider than the body of the downlight, however these tabs near the facing end of the light fitting will dig into the 12mm thick plasterboard. I'm struggling to understand the purpose of these, other than to damage the plasterboard and make it more difficult to push the light fittings into place. I can only assume they are meant to stop the light fitting "twisting" and possibly to hold it more securely, but why, when they have two powerful spring loaded anchors? It also means it is necessary to be very careful about what direction the fitting is installed as once pushed into the hole, it can't be turned.
