Good evening all
Occasionally my outside tap doesn’t work. When this starts to happen, It seems to start working again if the kitchen sink tap is turned on and off a few times. Isolation valve is turned on, there is a double check valve after that but out of sight behind the back panel of the sink cupboard and then a check valve in the tap itself. I have removed the tap and sometimes still no water. I have let the water run to flush pipe work when it has when water flows again with the tap removed. I think the double check valve may be faulty. Is that the likely culprit stopping the flow?
finally, what is the small nut / cap underneath the body of the outside tap?
Thanks in advance for your advice.
mutley 56
mutley 56
