What is this drain cock
25 Aug 2012
Berkshire
This drain cock is blocked.
I was planning to remove it. There is written 1/2 on it.
However the new drain cock I bought with size 1/2 appears a bit smaller than the one installed.
Please check the picture.
Have you seen this drain cock? I can't find it anywhere online so I wonder if this is very old.
Is my new drain cock the same size?
When you've unscrewed the old one you'll be able to compare the threads.
The odds of success are good.
OP ... As far as you need to worry then they are the same, the new one will replace the old. Don't forget to seal the threads.
You'll need to drain down before fitting the new drain cock. Hope that's not the only drain point.
