What is this used for?
Main isolating valve has to be the screwdown type cm. ;)
Yes get it repaired or replaced. These are more designed as a tempoary isolating valve, ideal for wc's or header tanks when you want to change the ball valve etc.
They also restrict the flow as internally they are only about 6mm diameter.
Did you find any hoof prints on your drive after the plumber installed the "valve"? :rolleyes:
Suggest you get a good plumber in to change the existing stopcock (or even service it). Can be done without getting the Water Company involved by someone who knows what they are doing.
dont think the punter had any one in giblets, just asking about his stopcock
corgiman said:
Does it??
No, it doesn't. :oops:
That was me showing my age - I was remembering them there auld bye laws, whereas the current Water Regs permit a spherical valve as the main isolating valve.
In an attempt to distract from my unforgivable error, what do you think of this valve - click on the image and read the poorn - raw sex innit?
I know - it's too much isn't it?
The bit that had me literally suppurating with desire was this:
Arrow Valves said:
The BV209 has a serviceable PTFE spindle seal with gland nut. The nut can be tightened or the seal renewed in service.
