The supply comes in encased in lead pipe. This appears to have a L and N. The lead casing goes to Earth block. Then earth bonding and earth from CU connect to this block. The L goes to meter and on to CU, the N goes to meter and then CU but there is also a cable between the N and the Earth block.
So diagramatically (this might not work):
[code:1]
L N E
***** 3 separate connectors
*** | Meter
***** CU
[/code:1]
So I tried working it out from the descriptions on TLC's guide. Is it TN-S or TN-C-S? From the description of TN-S I didn't think the N and E would be linked at the property (as well as obviously at the transformer).
The other possibility is than I have only L and N/E and the link to the sheath (lead pipe) is just earthing rather than a connection all the way back.
In case it help, the house is 1960s ish (former MOD) and in the MEB (East Midlands) area.
[code:1]
L N E
*** | Meter
***** CU
[/code:1]
