What Kw shower can I use??
6 Feb 2013
Lanarkshire
Hi, I'm doing up my ensuite bathroom and in my wisdom chucked out the old electric shower before checking the kw rating on it. How can I tell which kw rated shower I can use? Had a look at the fuse box but cant see a rating on it. Any help really appreciated.
Three things:-
What size was the mcb/fuse protecting the circuit ?
What size is the circuit cable ?
What is the type and set-up of your consumer unit ?
Three things:-
Fourth thing - how is the cable installed, i.e. does it run on the surface of walls, is it buried in loft insulation etc?
It doesnt say the size on the fuse box. Do i need to remove it to look at the back or something? How do you measure the cable, do you simply measure the diameter? The house is around 12 years old, persimmon built if that makes any difference.
And if it is run on walls, is it in conduit or trunking?
That will reduce the current carrying capacity.
It doesnt say the size on the fuse box ... The house is around 12 years old
Can you describe this fuse box for us. Is it a consumer unit (ie. a row of circuit breakers, each with a switch)? If so are there any markings above the switch for the shower? (such as B32 or B40)
The 'fuses' in my 'fuse box' don't say what size they are either. Just some silly code like NSB20. One of them, with a strange yellow button on a 6 Amp light circuit actually has 30mA written on it, how daft is that? :)
Nowhere near as daft as you.
Thanks, I'll take that as a compliment.
OP: If you haven't been scared off already, try to ignore the off-topic posts. I want to help but I find it hard to say anything on this forum without the resident bully sticking his/her nose in.
There were no off-topic posts until you wrote this:
I see no bullying going on.
Oh, OK, I must be wrong, Sorry :oops:
I do hope the OP replies.
I want to help
How can you offer real help when you cannot understand the coding of an MCB
or recognise an RCBO or RCD is not the same as an MCB
And as for
What you call bullying is ( in this case ) valid comment on un-helpful postings from you who by your own postings show a lack of knowledge and hence a lack of ability to offer constructive help to the people seeking help.
