I am in the process of converting my garage, had building control round and mentioned the size door that I want to put in the rear (1900mm) simply said use the same lintel you have just longer (currently a approx 900 door their currently.
Garage is attached to the house with its own pitched roof.
I was thinking of using the following CCS Single Leaf Wall Lintel 2250mm (SWL 20 kN):
http://www.condell-ltd.com/ProductDetails.aspx?ProductID=17626
Read on here that it's not advisable to drill into these, which I guess I will need to do in order to properly install the door frame (by fold doors). Any advise would be appreciated.
Existing is a Catnic see in this pic
