- Joined
- 29 Jun 2014
- Messages
- 3
- Reaction score
- 0
- Country
Hello,
I am installing some shelves (ikea Algot 650mm wide) in a 665wide cupboard.
My flat is in a new build where walls are made of plasterboard with metal studs.
I started installing Super Toggle fixings on one side without problem ... But unfortunately when drilling the wall to place fixings on the other side I realised I am just above a metal stud.
Given the cupboard is just 10mm wider than the shelves, I cannot move slightly to the side to avoid the stud.
I thought I could circumvent this issue by fixing a panel of the size of the shelves (650x840) on the wall first and attach the shelving system to that panel.
But what material shall I use?
MDF: it seems a bit complex to use (pre dril, countersinking etc.) and because the shelves supports would have to be screwed close to the edge of the panel , I read that i could end up chipping the panel off.
Plywood: that seems to be my best option, would you agree? If I use an 18mm board would it be enough to carry the weight of the shelves (not going to bear too heavy loads... Towels, washing powder etc.)
Contiboard: what is it?
Chipboard: I have a feeling that a 18mm chipboard would be good to fix shelves on, what would you think?
Please let me know what you think I should use.
Thanks for your help.
